Metropolitan
Stone specialises in stone repair and restoration involving complete
renewal, insitu surface restoration or consolidation. Causes of
stone masonry failure are most commonly; incompatible materials,
inadequate weathering and poor quality existing repairs.
External stonework often requires cleaning in order to adequately
identify concealed defects. Once diagnosed, various repair methods
can be adopted depending upon the type of stone masonry and the
extent of the decay.
New pieces of masonry can be indented into an existing structure
to replace defective areas of stonework. Each piece of stone is
carefully measured and cut to fit before stainless steel dowels
are drilled into the stonework, set in an annulus of epoxy resin.
The stone is then fitted into its position within the host substrate.
Stone repair can also involve cutting out the bad repairs to the
defective masonry using restoration mortar. Non ferrous reinforcement
is provided where necessary to build out the repair which are then
colour matched to the surrounding stonework as closely as possible.
Pinning and grout injection can also be used to repair stone. Grout
binds the defective stone producing in effect and invisible repair.
Email or call today to get a quotation.
